Help!! Rain leaking in!
Discussion in 'The Garage' started by ChevBlazin, Oct 8, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Every time it rains I have a pool of water on my front drivers floor mat. It drips out from under the dash and falls down near the e-brake. It is'nt dripping down along the inside of the fire wall, but it will drip down right from the lower inside edge of the dash. Not only is my carpet always wet, windows always fogging up, and floor rusting, I'm afraid it may short out some dash wires. Help! /forums/images/graemlins/1zhelp.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like you windshield is leaking /forums/images/graemlins/shocked.gif
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Or maybe the cowl?
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i would try replacing the windshield seal..
  5. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    I have the same problem....replaced windshield seal....did not fix it. My guess is something in the cowl that leaks, but have not found it yet.
    /forums/images/graemlins/usaflag.gif
  6. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Use soapy water and high pressure air.
    Spray windsheild moulding with soapy water in spray bottle the hit inside of your w/sheild with air and look for bubbles. continue this process on other areas until you find your leak. also check to make sure the cowl area is not plugged with dirt or leaves.
