Help reading Wiring Diagram
Discussion in 'The Garage' started by Hossbaby50, Aug 2, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not a master diagram reader so I was wondering if anyone can help me out here. I need to know which wires I need to bypass the ignition switch and to get the truck and accesories to run.
    From what I gather from the diagram the wires that I need to hotwire and toggle are
    http://www.jmr.4speed.cc/Tech%20pages/Wiring%20Diagrams/Chevy%20-%20GMC/Blazer%20-%20Jimmy/85%20CK%20Vehicles/2.pdf
    The wires I need help with are at the fuse panel.
    Red (powers bat terminals at fuse panel)
    Brown (powers radio)
    Pink (powers coil)
    Is the orange the accesories curcuits? What runs off those? I don't have AC anymore.
    I don't need the choke curcuit to work since I don't have a carb anymore. The PWR are hot all the time right? What are the WDO's?
    Harley
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If I was stealing your truck ( easier in 1st gens , same colors , switch pops off easier ) , I'd put red to pink and momentarily touch purple , and all should worky except radio which is brown . Orange is constant , which is why horn and some lights always work when truck is off . Red is constant . Pink gives you your blinkers , gauges , ignition /forums/images/graemlins/k5.gif
    I think WDO is your power windows /forums/images/graemlins/k5.gif
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    So I only need to hotwire the Pink and Brown to get everything to work.
    You don't need to touch purple since I have already bypasses my starter onto a toggle switch.
    Looks like I am going to have to implement new antitheft measures after I rewire it.
    Harley
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'd just change the switch . Call some stores tommorrow and see if they are cheap enough . Its not too hard to unbolt the switch and unplug it , its external on top of column under dash /forums/images/graemlins/k5.gif
    But if you wanted anti theft use several switches . You could use some momentary switches , one under carpet you need to hit with foot , and another for your finger to bump starter . Can't start without both as they'd be in line on purple . Truck thief would think your truck was FUBAR as they wouldn't realize the floor switch /forums/images/graemlins/thumb.gif
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    In GM vehicles colors are as follows:
    Red = unfused battery (+)
    Brown = Accessory (key turned all the way back)
    Pink = ingnition (+)
    Orange = fused battery (+)
    Purple = starter solenoid trigger
    Orange will typically power any circuits that require constant power: i.e. clock, courtesy lights, brake lights, lighter, radio memory.
    Brown will typically feed accessories that get "cut off" during cranking only: i.e. radio and A/C
    Pink will feed anything that needs power when the key is on i.e. distributor, gauges, etc.
    Red is for anything that requires big power at all times i.e.: ignition switch, headlight switch and unfused bat ports in the fuse block.
    From this you should be able to decide what you want to run off of each circuit. One thing to be careful of is picking which circuits to run off of your ignition feed. I made the mistake years ago of triggering the cooling fan relays off of ignition, which when I get into a low battery situation will prevent it from starting because of too much draw. If I had it to do over again I would trigger the fan relays with accessory power so the fans would turn off while cranking, allowing the starter to get all of the power it can. Just my $.02 though.
    Good luck with it.
    Nick
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    How many amp fuse should I use on each line? Or should I just run it on a hotwire toggled and let the normal fuses take care of everything? Thanks
    Harley
  7. mosesburb
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Just let the existing fuses take care of it. That way if you have a problem you are not hunting all over looking for an inline fuse somewhere else.
    I read your other post about broken stuff in the column. Chances are you just broke the plasic pinion gear on the back of the lock cylinder or the rack it meshes with. Those pieces are available in a kit from GM for small money and even if the upper bowl of the column is damaged, that is not too expensive either. Over the years the car theives damaging the columns have made these pieces less expensive. None of these are very difficult to change. Keeping the column intact would be a better option than re-working a harness to eliminate an otherwise reliable setup. Leaving the harness intact will eliminate ALOT of issues when trying to diagnose an electrical issue down-the-road.
    Just one guy's opinion though, take it for what it is worth.
    Good Luck,
    Nick
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    There were little broken plastic things in there along with the broken metal bar. I couldn't tell you what all was trashed as I don't know much about columns but my roommate how knows more about it then I do said it was pretty trashed and someone else on here mentioned if those metal bars were broken then I should just drop in a whole new column.
    My answer was to rewire it onto a toggle.
    I am going to use a 50 amp toggle. Will that be enough to hold the power drawn by the fuse panel and other interior stuff?
    Harley
    Harley
  9. mosesburb
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Well, I don't necessarily agree with their diagnosis as I have repaired columns that were more damaged than that (theft recoveries) for under a hundred, but since your decision has been made, I belive a 50A switch MIGHT do the job, but I would feel a whole lot more comfortable if you broke a couple/few circuits away from that switch to run through another 50A switch. With an approximate even split of amp draws, two switches should be safe (at least safer than just one).
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am splitting it to 2 50 amp switches. One will power the pink wire for the coil, ecm, etc. The other will power the orange and brown wires. My stereo isn't very powerful and has crappy speakers. I also left the red leads that are hot to the fuse panel connected like the are.
    Harley
