HELP!! Rear glass stuck
Discussion in 'The Garage' started by okjimmy, Mar 29, 2007.
  1. okjimmy
    okjimmy Newbie
    Feb 1, 2005
    3
    tulsa,oklahoma
    How do I get my rear window up.:confused: The cable is broken. Power window Thx James:bow:
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You'll have to take the access panel off the inside and push it up by hand.
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Take the panel off and attach a screwgun to the end of the cable and now you can manually roll up and down the window.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I left my panel off and there is a Makita cordless attached to the cable still.
  5. stout87k5
    stout87k5 Registered Member
    Feb 19, 2007
    21
    ne washington
    remove the acess panel and look down at the bottom of the glass you will be able to see the bolts that hold the glass to the lift arm remove the bolts with open end wrench and you will be able to remove the glass.you might have to do it this way if your cable is all shot out like mine was.if not the drill method might work for you.
  6. okjimmy
    okjimmy Newbie
    Feb 1, 2005
    3
    tulsa,oklahoma
    Thanks you guys rock.:rolleyes: I will have to cut back the outer cable some to attach a drill but I'm sure that will work. If not I can always unbolt it. :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
