Help rebuilding a 208, er uh, looks like a 205 it is!
Discussion in 'The Garage' started by MuddinManny, Apr 11, 2007.
  1. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Okay guys, I need the transfer case masters to step up to the plate. I've done the search and so far all I can come up with is that when rebuilding a 208:
    1. Make sure you open it on the correct side or the guts will spill out.
    2. Change the planetary to a 241 because it's stoudter (6) instead of the 208's (4).
    3. Upgrade to the 241 Chain, as the 241 chain is stronger and beefier than the HD 208 replacement.
    Other than that, I'm getting BCA's rebuild kit. Here it is:
    [​IMG] [​IMG] [​IMG]
    Transfer Case & Manual Transmission Kits Include all necessary Gaskets and/or Gasket Eliminator
    What model years have the 241? What part numbers for the planetary and the chain? Can I do this rebuild in a day? I truly don't know what else to ask, so please, everyone chip in and help me out. I'd appreciate it.
    Manny
  2. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Okay, update...
    Little "google" and I found this:
    Transfer Case Chains
    Which NP241 chain do I go with? Will it fit directly onto the sprockets inside my 208? I'm completely dumb with this.
    Manny
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Find a 241 to put back there and swap them out. Then you are done nothing else needs to be changed.
    The 241 planetary will not fit in the 208 the designs are different. An added benefit of a 241 is the availability of slip yoke eliminators. No one make one for the 208 that is not cheezy at best.
    Ira
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Ira,
    Okay, I started to look into this and wound up looking at JB's SYE for the 241. How much $$$ would a 241 cost? I'm clueless. Seems like the 241 is much stoudter than the 208. Your thoughts?
    Manny
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I know where a NP241 pass drop from an 89 K5 is, for a great price, close to SA, TX. That's if he still has it. I was thinking about getting it for myself, in the event that my 89's 241 ever got munched. But I don't really want to get it and have it just sitting around.
    I'll PM you the info.
  6. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Thanks, I appreciate that!
    Manny
  7. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    No problem, Manny. I just hope I don't regret it.. LOL.
  8. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Whoa there Manny. If you are going to go into your 208, why not swap in a 205 and be done? Kenny has the adapter, I and many others have round 205's, and you have the correct tranny. Only other thing you'll need is a crossmember and maybe some driveline work.
    Oh, and you can pick a 205 that already has the slip-yoke eliminated.
    Jimbo
  9. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    cause that would make sense.:surepal:
  10. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey YZ, I'm new to the New Process Transfer case seen, so yeah, I'm a NOOB here. I'm asking the questions and trying to get it right. If asking questions, for my sake, and maybe the others who are a little timid to post, earns me the roll eyes, then so be it. Just remember, everyone was at a beginning and inexperienced sometime. Not offended, just replying so you understand where I'm coming from.
    Manny
  11. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you talked earlier in your thread about going to a 205 later, well why not do it now? then you'll only have to mess with driveshafts once. you have everything else built tough, why not the t-case also. with as much work as you have into it now, why not take a little more time and put the 205 in?
  12. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    I agree with this completely. Why I'm having difficulties pulling the trigger on it, I don't know. Maybe because I don't have a clear picture or understanding on the swap. Thanks to Jimbo and his patience and others, I'm starting to come around.
    Thanks!
    Manny
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A 241 is a direct swap for a 208. A 241 is not that much beefier then a 208, but does have the ability to go SYE easily. A 205 is stronger but has less lowrange (2.72 vs. 1.96).
    I would find a 241 in good shape and swap it in. 241's can be had regularly for about $200-300 in good shape.
    A 241 should stand up to some beatings as long as you don't have direct contact with objects to the case. Make sure you have a good skidplate and you should be fine. A 205 is the ultimate in strength but has less gear ratio. With a built motor though that might not matter as much.
    Harley
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    P.S. If you do rebuild the 208 make sure you open the case up with the input facing down (sitting on table) and seperate the case halves. You must remove the speedo gear before you can seperate the case halves. The speedo gear is the little round thing on the side of the tailshaft housing.
    When/if you pull the mainshaft appart do it in a pan or large bowl or something. Behind one of the gears on the mainshaft is about 80 large needle bearings that will go all over the place if you don't contain them. Splitting the gears off the mainshaft may not be necessary unless you are wanting to replace those needle bearings.
    Harley
  15. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Okay,
    Well, it looks like I'm heading down the road to a 205 swap. I gotta pull the trigger. Having that slip yoke back there makes me feel real uneasy in case I dump the rear shaft and I don't like the idea of getting stuck in the middle of no where because my drivetrain is slinging fluid.
    Since I'm a MUD guy, losing the low range of the 208 isn't that big for me. My 383 should make up the grunt force difference. I'm gonna snag the adapter from Kenny and now I have to go and find a matching 205. If anyone can help shed some light on the 205 crossmember, I'd appreciate it. My current one I guess is a no-go. Grrrr! Oh well, suck it up. I'll be better off in the long run.
    Manny
  16. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    good to hear. your engine will make up for the low range.
  17. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    You should do the 205 now, and later on down the road, if you want more lowrange swap to a lomax 205
