Help removing steering arm stud on dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, Oct 8, 2001.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I started tearing the Dana 60 apart last night to rebuild it. Every thing went smoothly until I got to removing the steering arm. One of the cone nuts, broke, leaving the cone part which makes it extremly difficult to remove the stud, which is now twisted off just above the broken nut, because of this. I am replacing the steering arm with a cross over unit from ORD so I don't mind damaging it as long as I do not tear up the knuckle. Any ideas before I go do something to make it even harder to get out? Do I have to remove the stud to get the steering arm off? Or should the arm slide off after the remaining peice of nut is out of there?
    One last question. Do I have to have the special tool to remove and install the king pin, or is there a more economical way to do it?
    Some days I just pray for spontaneous combustionhttp://photos.yahoo.com/dana60manual
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    hey i just went through that, but as i was selling the parts i had to do it damage free.
    i ended up removing the knuckle and spinning the steering block which undid the stud from the knuckle. then took the block to machinist to drill the siezed stud from the block.
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Tell ya what I'll give you my D44 and yuou give me the dana60 then you wont need to take it off....
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    I will give up 2 D44's for the D60 for a spare.Why waste your time on it........LOL.
    chevrules...always has and always will
  5. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    mmm hhmmm...I'll let you know if it becomes to much of a pain. Not likely though so don't hold your breath. heheh
