HELP!! S.E.S. CODE 24
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rh88k5, Nov 8, 2002.
  1. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    oes anyone know what code 24 is? S.E.E. light comes on after driving a few minutes. T.I.A. /forums/images/graemlins/mad.gif
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue"> Code 24- A vehicle speed sensor malfunction will set this code. The conditions for it being set is vehicle speed at 0 mph, engine speed between 1500-3000 rpm, tps less than 2% open, and the transmission not in park or neutral. These conditions must be met for about 10 seconds. A faulty VSS will affect the operation of the TCC, IAC and ignition timing.
  3. rh88k5
    Sep 11, 2002
    94
    Burlington, N.J.
    where is the "vss" located?
  4. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    transfer case output i believe
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] See your other post about the VSS for a lengthy answer to this question. /forums/images/graemlins/wink.gif
