Help SB 400??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Sep 30, 2001.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I am thinking about getting a 1977 blazer. It has a camper special emblem on the back if that means anything. My question is can you tell the difference between a 400 and a 350. I know that the 1970 400 have 3 freeze out plugs in the side of the block but I don't know if that holds true for all of the 400 engines. Also I know the balancers are different than a standard one but what is it that I need to look for. I am going to look at it tomorrow any hope would be great. Thanks
    Donovan
    Nitro Fumes makes me Horrrrny
  2. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    The balancer has a cut out in the casting on the 400.The 350 is smooth all the way around.
    chevrules...always has and always will
  3. Donovan
    524
    Arvada, CO
    Great thanks.
    Donovan
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    If it has a camper special emblem, maybe it was an old Chalet model that came with the big camper at one time. Seems like those models had the 400 motors, usually. AZBLAZER might provide you with some clues to spot this.
    9/11/01..Never forget...Never forgive
  5. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    This doesnt apply to a 400 sb but was just wondering if anybody knew exactly what the camper special was?My 3/4 ton truck had these emblems on it.
  6. i think with the sb 400 you will also get a 4 core radiator. my 78 came stock with both. i also had 3.42s in the axles too, so check that out if you can. maybe the camper special will get you 3.73s at least. good luck!
    <font color=blue>"What does mine say?"
    "SWEET! What does mine say?"
    "DUDE!" </font color=blue>
  7. chevrules
    Aug 26, 2001
    127
    Canada
    usually the camper special was just some extra springs in the rear...and maybe a rear sway bar
  8. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I have a 77 camper special K25 pickup... its 8400 gvw which basically translates to heavy duty springs, and other stuff that you'd need like dual tanks (on a truck) bigger motor, heavy duty cooling, etc..
    as for spotting a 400 small block, start it up and crawl underneath the front bumper and look up at the back (engine side) of the balancer.. if there is a huge cut-out in it for counterweight, then its a 400.. thats probably the most fool proof way.. if its smooth as the balancer spins, its something else..
    mike
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    And most 400SB's have a casting number in the block, looking up from under the truck...........of 509. Large numbers about an inch or an inch and a half high.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  10. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If I remember right the 3 freeze plugs in a 400 meens that its a four bolt and 2 freeze plugs meens it's a 2 bolt . So as far as using this as an identifier don't, cause this could be misleeding .It could still be a sb 400. Easiest way is check the balancer.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Does it slam you back in the seat on heavy acceleration? :)
    Tim
  12. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Are you sure it says camper special and not trailering special?
    I have never seen a K5 with camper special badges on it.
    The Chalets ended in 76.
    My Burb has Trailering special badges on it and my pick up has the camper special badges.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  13. Donovan
    524
    Arvada, CO
    I am pretty sure it said camper special. Buy the way I went to look at it last night and it was a 350. It looked like it was a 400 at one time but now it was a 350. The balancer was smooth all the way around and the casting on the side of the block was 010. I think I might still get it if he will come down.
    Donovan
