HELP!!sbc, th400, np205 swap
Discussion in 'The Garage' started by mrdrinksalil, Jan 15, 2007.
  1. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Anyone got pics of the factory crossmember for this setup and how its installed. I can't get any holes to line up and im begining to think my frame is bent :eek1: :eek1: ... I have an 85 k5 frame
  2. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I have the double hump crossmember. What does everyone else use for this swap????!!!
  3. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I just did a 465/205 swap from a 700/208 combo and i had to drill new holes in my crossmember. I only had a single hump cross member but i thought everything went smooth
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    if the tcase adaptor is short then w crossmember is needed. if tall adaptor then flat one is needed. and will probubly need to drill holes.
  5. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    i just did a 700r4/241 to a 465/241 and used the same x -member and same holes. but i can take a picture of my other truck cross member that has a bbc-th400-205 for you tommorrow. but it's a v30 drw
  6. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Thanks. I think I've figured it out. I have a short adapter on my 205 and will need the w style crossmember. I am also going to have to driill 2 more holes.
