HELP setting timing
Discussion in 'The Garage' started by nvrenuf, May 5, 2003.
  1. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Can someone please tell me the correct procedure for setting the timing on my 91 V3500 w/ 350 (all stock / original)?
    Chilton's says (before adjusting) "disengage the timing connector... next to the distributor" but gives no information or pictures about identifying this connector. Anyone familiar with this? I don't want to just randomly start unplugging junk and screw up.
    Thanks in advance for the help!
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If you follow the wiring harness where it comes out of the fire wall, there is a lt brown/black stripe wire that comes out of harness with a quick disconnect in it.
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    You da man!! /forums/images/graemlins/thumb.gif Thanks, I'm headed out to fix it now!
    Funny, I was replying to yours while you were replying to mine.
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Ok, I'm stupid. /forums/images/graemlins/blush.gif I can't find the connector. Is it in the large harness bundle above the pass side valve cover or the small harness above the driver side valve cover? Also, am I looking for a cap connector that terminates a harness or a junction plug inline?
    Thanks again!!
