HELP! SHEARED SPLINES OFF CADDY SLIP YOLK!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by topless1tonk5, Jun 10, 2002.
  1. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    was being evacuated for the fire in pine co. today and had to toss my rear under my k5 fast! bolted it under and did not realize the rear was now angled down a few more degrees and it pulled the slip out too far as i was trying to leave and trashed the spines on the onside of the slip, output seems ok, i forgot what caddy i pulled the slip from, any one know? can they put a reg. slip on my caddy c.v.? i need help quick! thx--j.c. /forums/images/icons/confused.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Call Jesse at High Angle Driveline. Or you can reach him at his website, www.highangledriveline.com. Jesse has the correct C/V shaft slip yoke you need. His slip yoke is splined all the way to the end, unlike the caddy slip yoke.
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    76-78 or there abouts, i have one from a 77 Eldorado in my garage. you want it? make me an offer!! i used the other end off it, so i got a big piece of tube with the slip yoke, still has factory joints, and the centering ball should be almost perfect, the other end was. /forums/images/icons/smile.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The big question is this: Did you get it out of harms way? I can see the smoke plume of the Hayman fire from Colorado Springs. They say that the fire has slowed down a bit today, since the wind has eased. However, that's still one REALLY big fire and it's still headed your way. /forums/images/icons/shocked.gif
