HELP!! sliding glass
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Dec 26, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    does anyone know how to remove the sliding glass on a topper?
    i need to know
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i think i have a pretty good idea of how to do it. Get one of those windshield tools that pulls the middle part of the rubber up. You can also use a samll screwdriver. Work it all the way around, until the center part is up, There should be a plastic cap where the two ends meet. Pull that up too. I think that the window frame is attached under that part. It may be glued down. If you've ever taken off a windshield, it should be similar. I've seen someone do this, but this is all I remember.
    90K5
  3. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    any one else have any imput?
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Are you talking about the sliding pane itself or the whole window? Is it the left side? Do you want to sell it? I think there are small phillips screws you can take the frame apart with, without removing the whole frame. I'm looking for the left sliding glass, not the whole thing, just the glass.
    creepin' and crawlin'
    Jim
  5. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    yeah i am selling it.
    do you want the small part that covers the latch or the part that slides.?
    let me know asap
    email me at Confederate9@aol.com
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Hey ill buy the right side.Are they tinted?My wife hit a tree with mine and it cracked the slider.
  7. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Does your topper have the small wind/wing windows? (Don't know the official name for them) If so, do you want to sell them. They were missing on my K5 when I bought it.
    '89 K5 Silverado 4" lift w/BFG 33's
  8. dyeager535
    26,979
    Yes, its really easy. Pull the rubber "spacer" from the gasket. Start in a corner, from the inside, and work, with a screwdriver or less sharp object, the inside edge of the gasket under the lip of the shell, so that finally the inside of the gasket is on the outside of the shell. Once you have got it started, keep going. Hardest part is doing it without ruining the gasket. There are no bolts holding them to the body, just gasket. On my '83, and the sliding topper I picked up, there was no sealant either.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  9. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    sorry guys
    i sold the drivers side to jimmyjack and
    the passenger side to gokartergo
    i have some other parts for sale, like a front axle anda hood ornament.... and a 40 series flowmaster for sale.
