Help! Steering Box Going, Need Recomendation for New One
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bross82, Aug 9, 2002.
  1. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    My steering box is pretty much almost done... I am on a pretty tight budget and I need my truck as a daily driver, so downtime must be as little as possible. So I dont think I'm gonna be able to send my steering box away to the west texas guy to have it rebuilt.
    So, I was wondering which steering boxes are recommended in the $300-$400 (max) range..... and which, if any, already have hydraulic fittings so I can later hook up a complete hydraulic steering system.
    Also, I noticed some have different ratio's.... which one would be ideal for light to medium trails, more rocks and stuff and a little mud, and I plan on later having 36''x14 tires...
    thanks a lot,
    matt
    I am trying to order today if possible, thanks again
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> AGR's boxes are under $400. If you don't mind a little twitchiness on the freeway I'd get the S series box. </font color>
  3. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    how twitchy is it.... i dont do highway driving often... but i typically drive at about 40-50. just want to make sure this one isnt too sensitive for daily street driving, i saw the warning on the 4wheelparts site saying its not recommended for highway speeds.
    thanks again,
    matt
  4. dyeager535
    26,980
    Are you certain its the box and not some other component or cracked frame? Just wanting to make sure you don't dump a ton of money (I know that boxes are pricey new) and then find out something else is bad like drag link or cracked frame, worn out pot/rag joints, etc.
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    You are sure it is the box right? Why not just replace it with a used one. I have one that I replaced with a 2wd for my cross over.
    Ken H.
  6. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    You can get one at an auto parts store for around $200. I've never seen anything wrong with the stock boxes. I'd go junkyard hunting first though.
  7. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Hey ive got one set up for hydro already that I cant use now......I went to a late model ifs to solid axle so I am using the box on it now.The box Ive got Is already setup for crossover and has the fittings on it for hydro setup.works great and I will sell for 100.00 plus shipping............Its still on the truck so if you want to feel it or see it let me know,also leak free...........Im in N.C. so let me know!!!!!
  8. mudddog91
    Dec 28, 2000
    471
    north carolina
    Hey you interested in the steering box or what?
  9. Grim-Reaper
    7,385
    Atlanta
    If it's leaking then reseal it. Get the numbers off the side and take it to autozone. The seals are under $10 for both input and the two output seals. the output seals are real easy to replace...it's messy as hell but easy. Choppy steering is usualy not the box it usualy the pump and screwing up an not providing enough pressure.
