Help !! Steering box I adjusted the screw.. now it's too tight..what next?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Dec 6, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Help !! Steering box I adjusted the screw.. now it\'s too tight..what next?
    I installed new tie rod ends on the Blazer, then it threw off the steering wheel.. well that's no big deal.. i can fix that.. <font color="black"> Here's what I did.. what do I do now? </font color>
    I backed off the locking nut on the steering box.. I used a allen key to adjust the adjustment screw.. I made the steering way too tight. Feel's like I'm fighting the wheel and it's hard to get back to center.
    What's the correct way to adjust this nut.. Chilton's manual is very "vague"
    Which way to I turn the adjustment screw to loosen up the steering.. I don't want to burn up my steering box..
    Thanks in advance..
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Re: Help !! Steering box I adjusted the screw.. now it\'s too tight..what next?
    The correct way to adjust that steering nut (the one witrh the nut and allen head in the middle) is to jack the truck up, disconnect the pitman arm, and use an in/lbs torque scale on the steering wheel itself.
    The correct way to adjust the steering wheel center is to loosten the bolts that hold the center link in place and turn the center link with a pair of channel locks. The steering box allen bolt should not be used to adjust the steering wheel centering position. If it is, you'll have more steering throw one way than the other (in other words, you'll have a tighter turning radius right, and less on a left turn -- or visa-versa)
    Thomas.
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thomas.. thanks..
    Do you recall which way to turn the allen key to loosen up the steering?
  4. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Turn the allen head counter-clockwise to loosten the steering up. Lemme know if you need some help, I get out around 5pm or so.
    Thomas.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The way I do it is tighten the steering until it's frim like you said and then back to loosen it half a turn.
    It makes tight enough without binding
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Rocko i gave you some directions on your other post
    hope it helps.
  7. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks for all the suggestions..
    It's back to normal now.. I can finally drive it without fighting it. /forums/images/graemlins/thumb.gif Thanks for the extra set of hands Russell.. aka txbluethunder.
