HELP!!! Steering correction for Body lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trag, Nov 30, 2002.
  1. trag
    trag Registered Member
    Oct 28, 2002
    7
    Raleigh, NC
    I just put a 2" body lift on a 89 blazer, and the instructions confused me about what to do to correct the steering. It said something about knocking pins out of the slip joint on the steering shaft, but I didn't see any pins. I can get it to bolt up after I put the lift on and everything seems to work fine, do I need to do anything else?
    Trey
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    No, you'll be fine, if you unbolted your steering column from the firewall and from underneath the dash before you lifted the body, then reattached after the lift was done, it will be ok.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    just unbolt the rag joint and pull it out. once its out burn out the 2 nylon pins and put it back in. some things to think about is once its apart and long enough you have 2 options. 1 is to just leave it alone. this could be bad because if the 2 shafts seperate while twisted up your done. the second is to put a bolt in to keep it from seperating but this takes some consideration because if you bolt it and get into a accident the steering wheel will not colapse and your chest will have a hard day.
  4. trag
    Oct 28, 2002
    7
    Raleigh, NC
    Thanks for the help. I got it back in and it seems to working fine.
    thanks
