help.. steering dampner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GAK5, Oct 4, 2000.
  1. 89GAK5
    89GAK5 Registered Member
    Sep 18, 2000
    22
    GEORGIA
    89gak5 back seeking no how again.my steering dampner is leaking oil.i bought a new one today afte work.it look like replacement was going to be a breeze.well one end came loose fine.the other:a real pain.is this end pressed on? on the new hardware it looks like the shaft is tapered going into the tie rod.i tried a hammer but not a budge.please shed a little light on this for me.a 500 watt halegon would be great. i need all the light i can get.any way greetings from middle georgia. thanks
    RUGERS & K5 BOWTIES
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    yea it is tapered in there but i shouldn't be to bad to get out, spray some penetrating fluid on it and let it soak in. Then beat it, and if that doesn't work for some odd reason heat it up a little. Oh yea if you want you can take the castle nut of on the back turn the car on and just move the steering wheel back and forth and that may take it out too. - Doug
    Doug Krebs
  3. 89GAK5
    Sep 18, 2000
    22
    GEORGIA
    thanks for the in-put.will try this tomorrow.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    As far as the penetrating oil goes, PB Blaster works great, even better than Liquid Wrench and the stuff the military uses.
    [​IMG] Semper Maintenance!
