Help!!! Stock Steering arm Removal
Discussion in 'The Garage' started by jekquistk5, Jul 3, 2004.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Hey guys today is the big day, atleast for me im installing a new TC 6" lift with the drop steering arm. The thing is i cant get the damn stock one off. I have WD' the hell out of it, Hit it with a sledge a few times, still no luck. I know if i use heat ill toast my ball joints, any tips to get this damn thing off!
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    big hammer,few swear words and a cold beer should do the trick /forums/images/graemlins/waytogo.gif hit it up and down and from the side and it should pop right off.
  3. jekquistk5
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Thanks ill give it a try, oh and on beer number 3
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    pb blaster, soak, resoak, smack it a few times on the back of the arm forward, use pliers to grab the conical washers and try to thread them off/out, then smack the arm from the back a few more times.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    The best way I found was to start soaking it the week before. Then the day od the swap.. Loosen the nuts about half way.. Frive around the block slowly.. It will come off by the second hit... /forums/images/graemlins/eek.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    done that didn't work for me /forums/images/graemlins/dunno.gif Damn rust /forums/images/graemlins/whistling.gif
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Gotta look where he's from...California.
    Here in the rustbelt, steering arms are MAJOR pain-in-the-asses.
    jekquistk5 - search "the garage" for rustbelt steering arm ...this was discussed no more than a week or two ago.
  8. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    On the top of the arm, toward the draglink, theres some numbers stamped on the upper surface.
    Take a BFH and hit it a couple times right on those numbers and the cones should pop up. Took 3 hits to remove mine.
  9. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Too much salt on mine. I pounded untill I couldn't lift the &*(kin' sledge off the floor. Gave up... I just don't hold the wheel to tight when hitting the brakes or running down a bumpy trail.
    I'll wait for another cold day to start swingin' that BFH again.
    10 pound sledge and about 100 swats from all directions wouldn't move mine.
    Sawzall next?
  10. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    When I had to remove mine, I was told to use a BFH. Now, at that time, I thought a BFH was a 5 pound sledge, or, at least, that is all I had. I couldn't get that thing off until I borrowed a 15 pound sledge from a friend. Still took more than just a few hits, though.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have always had to remove the axle and use a huge sledge with overhead hits to get it loose.
    On the D60 they did you a favor putting a spring in there that pushes it off. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i found that out myself too, i never heard anyone else know of it though, until now. . . took me 2 hits on the numbers after over 35 minutes of beating around there...
  13. jekquistk5
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Hey guys thanks alot, i got it off though but not done yet! I ran to the store and grabed a 5 pound hammer, the sledge couldn't clear the tie rod. 10 hits and alot of WD and it worked!
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif time for another beer /forums/images/graemlins/waytogo.gif
    I guess us cali guys got it easy /forums/images/graemlins/ignore.gif
  15. 88Silverado
    Mar 13, 2003
    2,664
    I spent 2 hours with a 5 pound sledge and couldnt budge mine when I did the lift last fall. Someone on this site told me about hiting it right on those numbers and the damn thing came right off. Seems to be a sweet spot to pop the washers up /forums/images/graemlins/thumb.gif
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    when I did mine I tried using a air chisle and that didnt work so if you have access to a lift like I did just remove the tie rod then hit it straight up from the bottom, it poped off after a few hits. /forums/images/graemlins/thumb.gif
  17. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i bet it was me /forums/images/graemlins/laugh.gif
