Help Stuck in 2wd
Discussion in 'The Garage' started by coptezr, Jul 4, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    my 83 wont come out of 2wd when the hubs are locked in and when the hubs are free the front driveline wont turn?
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    the same thing happened to my buddies 84 chebby, he busted something in the transfer case and the 4hi was getting stuck, not allowing the front drive shaft to turn.
  3. coptezr
    Jan 13, 2005
    342
    so do i have to by a new transfer case?
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    if that is your problem...you should put the tranny in neutral and see if the rear driveshaft spins, check your linkages or even check out the front diff. i dont want to make someone go out and spend unnessary money. i was just saying that was one experience that i have encountered.
  5. coptezr
    Jan 13, 2005
    342
    thanks anyone else?
