HELP...stumbling idle/accelartion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Nov 7, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    engine intermittenly stumbles at idle while in gear.. place in neutural it stumbles less.. upon slow/mild accelartion it stumble a little and then sometimes heavely.. get on it hard and it goes away.. Have new control module..new distributor advance kit... Could it be my edelbrock needs rebuild?? /forums/images/graemlins/eek.gif
  2. dyeager535
    26,976
    Sounds like a vacuum leak or timing issue, at least in order of likelihood.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    How long since a standard tune-up? (plugs, wires, cap, rotor, fuel filter, air filter, etc...)
    Has this been going on for a while? Could it just be bad gas from your last fillup?
    Thomas.
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I had the same problem. Check to make sure the jets for your acceleratpr pump are not plugged. Jar the throttle to see if they squirt. One of mine wasnt squirting, pulled it apart and cleaned it. It helped alot.
  5. rcpilot
    Feb 22, 2002
    507
    Central Cali
    I tuned it it recently all but wires...no vaccum leaks..both accelarter jets squirt equally..started about a week and a half ago.. I was towing a rental trailer to move and started noticing it..1 tank full ago.. started using Texaco gas then /forums/images/graemlins/eek.gif ... filled it up with super on Tuesday..I'm putting a carb cleaner in it tomorrow...
