Help Swaping Rims
Discussion in 'The Garage' started by XBeastX, Apr 14, 2003.
  1. XBeastX
    XBeastX Registered Member
    Apr 16, 2002
    27
    Beaverton, OR
    I need to swap rims on a set of tires I have, but I don't know the best way to go about it. I could go to the tire store and spend $60, but I could use the practice before I have to do it on the trail. Any help or advice would be apprreciated.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The easiest way is to pay to have it done at local tire shop. /forums/images/graemlins/rotfl.gif
    If you plan on doing it yourself, you'll need to unseat the beads, sometimes that can be done with a block of wood and hammer. Once you unseat the bead, then you'll need at least two thin pry bars to work the bead up over the lip on the rim. Obviously you'll need to do that twice per tire. Also, mix up some dish soap and water solution to lube the beads so you don't tear them.
    All I can say is good luck, mounting tires without a machine is a pain in the hind-end. Years ago I worked for a local Goodyear, we mounted all big-rig tires by hand, now that sucked! /forums/images/graemlins/eek.gif
  3. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    What size wheel is it? if its 16.5 its easy if its not then good luck.
  4. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I work for a Dealership and have all the high tech equipment.
    I did try one time to see how hard it was to dismount and remount a tire what a pain in the ass also very scary when
    you go to pop the bead with air and the tire jumps off the floor.
    My opinion you sould have a matching spare and if that is not enough buy beadlock wheels..
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i went to americas tire corp and they did it for free. I think the key was how i kept talking about how I run 39.5" tires offroad and stuff like that. They start looking at you like "hmmm, this guy spends $1000 on tires on occassion, how can we get on his good side?". /forums/images/graemlins/grin.gif
    j
