help swapping in ff14bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by digity, Nov 20, 2004.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    I have a 90GMC Jimmy. /forums/images/graemlins/1zhelp.gif What is the difference if any between 2wd n 4wd axle n will 2wd work. Also what yrs. will fit and won't fit.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the only problem you might run into is spring perch spacing and shock mounts, oh and a hybrid u-joint might be needed. the spring spacing is different from the 1/2 and 3/4 to the 1 tons, and the e-brake cables might not match if its older than ur truck. i dont even have the ebrake cables on mine hooked up.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    oh yeah and new u bolts because the 14bff tube is bigger.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    spring perches between 1/2 and 3/4 tons is the same, its the 1 tons that are different. other than that, you are correct, possibly a conversion joint, and new u bolts and plates.
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    You should know that if you put new spring perches on and you tilt the pinion up for better driveshaft angles, you may not be able to attach the driver's side shock to the axle b/c it rotates the mount too far underneath the axle tube. Might as well get or make new shock mounts while you're at it.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I had a 4x4 once that had a 2wd 14 bolt in it and the stock shocks worked fine. Once I lifted it the new shocks wouldn't work because they both hit the axle tube.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah the shock mounts from a 2wd will work, but just about everyone that swaps in a 2wd 14FF will replace the stock shock mounts for different ones cause the 2wd shock mounts hang down to low and get hit. 4wd shock mounts are flush with the bottom of the axle tube /forums/images/graemlins/thumb.gif
  8. digity
    Oct 10, 2004
    184
    13
    Brentwood Ca
    Thanks 4all the info guys. I found a decent deal on a ff14blt off a 75 k20. Will that fit and is that a good axle or should I hold off for a newer one. My truck is a 90Jimmy.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That will fit right in there, only thing needed will be new u-bolts and a conversion joint /forums/images/graemlins/thumb.gif
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    All 73 - 87 I know for a fact are the same
  11. digity
    Oct 10, 2004
    184
    13
    Brentwood Ca
    104 thx I'm gonna grb this one then.
  12. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Yeah as everyone else said, but I would also get a set of tor up cadi calipers and use napa replacements and hit up some rear disks. The swap is pretty easy. Maybe chop a chunk off the bottom to gain a little clearance before you install..wish I would have done that. /forums/images/graemlins/grind.gif /forums/images/graemlins/hack.gif
