Help - TC engages mysteriously now that the K5 is lifted
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Aug 7, 2002.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    It has happened twice now----my TC engages out of the blue. And, since I have a different ratio in the front axle it is not pleasant.
    I just lifted my K5, as many have already heard about, and I did not adjust the TC at all, should I have????? The driveline angle did not
    change very much.....I have not other explaination why this happens. The shift lever does not move but for some reason the front driveshaft
    starts turning. I happened once in a parking lot after I went over a speed bump and again tonight but I do not recall hitting any major pot holes or bumps. Any ideas????
    Maybe my TC is on the way out. Thanks for replies.
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If it was a body lift you need to adjust your T-case shift linkage, a suspension lift shouldn't have done anything like that unless you lowered you t-case. Sorry I couldn' be more helpful.
  3. 1986Blazer
    Jun 13, 2001
    511
    It was a suspension lift ---- I guess that makes this a better mystery! Anyone else???
