help techs and shop managers
Discussion in 'The Garage' started by BROKEN-ONE, Feb 7, 2007.
  1. BROKEN-ONE
    BROKEN-ONE Registered Member
    Sep 15, 2005
    78
    kansas
    how hard is it to change the motor mounts in a 91' s10 blazer 4.3 l 4x4 ? and what is involved ? serious answers please . thanks for any help .
  2. BROKEN-ONE
    Sep 15, 2005
    78
    kansas
    please help
    ttt, being told the front diff has to come out of the truck to do this , and chilton is of no use .
  3. goldwing2000
    goldwing2000 Guest
    I know changing mounts on a 2WD was no picnic, so I can imagine a 4x4 is a real treat.
    Taking out the front diff shouldn't be a big deal, though. You might even be able to just drop it down out of the way without completely removing it.
    Check eBay for a factory service manual.
  4. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    try going to s10extremist.org or other s10 forums were people probably have experience in these..will probably save you some headache
  5. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    My book says 4.3 hours... so pretty much a bitch...
    gabe
  6. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    if you need step by steps just pm me a fax # for ya
    gabe
  7. BROKEN-ONE
    Sep 15, 2005
    78
    kansas
    Thank You
    thanks to every one who answered . i know its not a fullsize blazer . but it is good to be able to ask a question about this truck . many thanks .
  8. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    b1, Im still looking for the step by step instructions. The 4.3 hours is with a lift... I would not even think about doing it in the driveway... and this is from someone who has replaced a tj clutch on the trail...
  9. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i replaced the motor mounts in mine in my driveway it was not that bad, the worst part was getting a wrench to some of the bolts, its only 4 blots per mount, you remove the thru bolt and then using wood on top of the floor jack jack the engien up by the oil pan this gives you a lot of clearence to get at the mount and change it
  10. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    you realize its an s10 right?
  11. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes, i did it on my 93 s-10 blazer
