Help TH350 not shifting into gear...
Discussion in 'The Garage' started by mo, May 24, 2005.
  1. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    went to try to drive the truck for the first time since replacing everything, and I got nothin...felt like it was sitting in park. tcase (205) was not in nuetral and there is tranny fluid. i tried switching the gears by hand from underneath, but not while it was running ( no e break and no one else there to hold the brakes) i was thinking about either taking the shafts off or jacking up the rear end and trying it in 2 wheel drive, while its running...but any ideas as to what is going on? torque converter is spinning (maybe I didn't get it engaged right???)
    thanks
    mo
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    does it work in rear wheel drive? If not you need gears in your diff ...check those before you get crazy
