Help! TH350 went manual!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Mar 18, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Yesterday I took my Blazer for its first test drive around the block with the 454. Before I removed the 350, the tranny was working perfectly. Now, if I just shift to "D" and drive, it will stay in 1st gear all the time. I have to shift to L1 and when I want it to shift, move the lever to L2 and then to D. What's going on?
    I checked ATF level and it's OK. The kickdown cable is disconnected because the old bracket didn't fit the new manifold and the new bracket hasn't arrived from summit racing. I made sure the kickdown cable was not in the "pulled" position. I also connected the vacuum line properly.
    Any ideas? Thanks.
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Check all your vacume lines on the carburater, chances are thats your fix. Another thing to check is the kickdown cable, but I'm leaning towards the vacume lines.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    your not getting enough vacume
  4. swiggettbj
    swiggettbj Registered Member
    Mar 17, 2002
    7
    Paris Kentucky
    There are three things that can affect the shift of your old style automatic tranny, vaccum to the valve body, the kich down cable and the governer on the left side of the tranny. I've had simular problems when gov. would not expand as the tranny picked up speed
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I agree w/ mudhog.... Your vacuum line is pinched, has a leak, or not connected somehow.
    Marv
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I agree with the lack of vacuum...does you new BBC have a wild cam in it? make sure your engine is creating enough vacuum to run the brake booster and all the other vacuum related components (vacuum advance if applicable)...
    Chris
  7. Blazer79
    1,816
    Thanks for the replies, guys. I'll definitely check the vacuum line. I did feel it didn't connect tightly on the tranny end. Maybe that's it. Is it a good idea to seal all connecting points with silicone?
    The 454 was in a tow truck before. I don't think it has a wild cam. I can brake perfectly. I do have a fluctiation in timing, but I'm going to post a new thread on that.
    Thanks again.
