HELP TH400 install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Nov 20, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Got a 90 Jimmy w/700R4 and 241, just got deal on TH400. What all am I going to have to do to get this to work. I know I will need to move the crossmember,
    will I need to get an adapter for the mate to the 241 or will I need to get a diff t-case?
    And The 700 (4L-60) I have is not the Electric one but I someone told me it still has something controlled by the computer. Plus Im bolting this beast up to a 350 turned 383.
    Don't you buy no ugly truck!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You will need an adapter to mount the 400 to the NP241 and an out put or input shaft to match the splines.
    Anyone else think of other things? I am drawing a blank.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I am going thru this same deal on my 90 Sub. Getting rid of the 700 in favor of a TH400. The input of your 241 is now 27 spline. The 400 version 241 has a 32 spline input. I am trying to find out if these gears are easily interchangeable or not. If so, a new 32 spline gear and you're ready! Well, except for the adapter, which you can source from GM or a bone yard...even a TH400 to 208 adapter will work, which allows you to go back to 1981 model years looking for the adapter. Screw Advance, source the parts from a bone yard!!
    ken
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    the electonically controlled part of your non-electronically controlled transmission, is, I believe for the converter to lock up........js
