Help th400 problem
Discussion in 'The Garage' started by AnthonyG, Apr 7, 2003.
  1. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I got the tranny all bolted in but I can't move the tork converter to ligh it up it il pressed against the flexplate
    Do you have to lign it up befor you bolt the tranny in or what
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The Converter, should slide easily out of the pump, to attach to the flexplate. Are You replacing a manual trans?
    If so, did You remove the pilot bushing from the crank?
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Did You make sure the converter was all the way in the pump, before You bolted the trans. in? If the converter, wasn't seated in the pump, that could be the problem. /forums/images/graemlins/eek.gif
    You'll have to remove the bolt's, and spin and push the converter, to get it to seat. /forums/images/graemlins/blush.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yep, the torque converter is not properly indexed with the front pump. You need to pull the converter out a little and spin it and push back in, eventually you will find the spot where it will drop in about an inch further inside. Then when you bolt up the engine and tranny, it should spin freely you'll have to pull the torque converter forewards a little when it bolts up to the flexplate.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    yep the tork converter wasn't all the wat on but we fixed it and it is all good again
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    yeah, you install the converter and keep turning it till you here 2 "clicks"
