Help, The body twists too much
Discussion in 'The Garage' started by randknu, Sep 10, 2003.
  1. randknu
    randknu Registered Member
    Sep 10, 2003
    10
    Stavanger, Norway
    I have just bought a 78 Blazer K10 That has been converted to all-convertible with parts from a 73 I think it was. The conversion looks proffesionally done and all but it also removed a lot(most) of the stiffness in the body.
    Whith the springs mentioned in another post, in a flexed position, I have no way of opening the doors, /forums/images/graemlins/frown.gif and certainly not closing them
    I can actually feel the steering wheel move in relation to the seat.
    How can i simply stiffen up the body?
    How is the original full-convertible hanling flex?
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Install a roll cage!!! /forums/images/graemlins/grin.gif
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    My '72 was designed as a full convertible and I also cannot open the doors when the suspension is flexing....
    It's normal, but your truck may still be worse.
    A rollcage can help to triangulate and stiffen the body structure to minimize those effects.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There's only one solution for this....
    ...go doorless. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    But really, check the body mounts to see what kind of condition they are in. Short of replacing those, there's not a whole lot you can do to stiffen things up. Even at that, if you've got a lot of frame flex the body is still going to contort itself. You could add support to keep the frame from flexing so much, but it's not recommended. It's common for it to be hard to open and close the doors while flexing in these trucks (most trucks for that matter).
  5. randknu
    Sep 10, 2003
    10
    Stavanger, Norway
    Yes I have thought about adding a rollcage but will the body to cage mounts stand the pressure?
    Normal you say?
    Would like a rollcage anyhow.
    Is there any good prize effective complete rollcages or kits to buy?
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    your cag shouldn't mount just to your body. Should be some type of mounting setup on the other side to mount to the frame. A cag mounted to the body is as good as the body itself and i know I wouldn't trust my K5 body in a rollover.
  7. Grim-Reaper
    7,385
    Atlanta
    The real converts had extra bracing. On your truck the roof is what kept things lined up. YOU HAVE TOO ADD BRACING when you cut the top on a 76 up. The easiest thing to doo is a full cage tight to the A-piller and tied into the A-piller at the windsheild and the mid piont just below the dash.
    Do a search on "cutting the top", "full convertable" or "going topless". See what you come up with. There are several people who have done this and lots of good posts.
    Ignore Greg in his rust bucket. /forums/images/graemlins/rotfl.gif My 75 with full cage I can still use the doors when fully flexed.
  8. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    OW! /forums/images/graemlins/grin.gif
  9. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Have one of these made.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thinking.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ok who do I shoot to own that?
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Well me of course. /forums/images/graemlins/pimp1.gif /forums/images/graemlins/rotfl.gif
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    is there really a need for a body lift on top of it? ha
  13. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have hope of taking it out one day. /forums/images/graemlins/angryfire.gif
  14. Grim-Reaper
    7,385
    Atlanta
    Uhhhh DAMN! That's pretty cool!
    Is that set up for a Blazer or a truck?How tall is the frame rail efective hight? I like it but I would want to move the body mounts down a little to keep the CG a little lower.
  15. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    That is the frame that is under my blazer. Over all the frame raised the blazer up about 7-8 inches. To help with the CG the drivetrain was only raised about 2-3 inches. /forums/images/graemlins/thumb.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    so basically its like having a safe 8" body lift?
  17. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yes and It is a lot stiffer then the factory frame.
    I think it looks cool too. Maybe I should of had it dipped in the Bling Bling juice. /forums/images/graemlins/pimp1.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no offense but I hate it. The tube part is pretty cool but then I really look at it and I hate seeing any frame, factory rails or not. If you like it thats all that matters. Just like guys with 12" suspensions, if they like it more power to them.
  19. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Hey to each his own. /forums/images/graemlins/smirk.gif
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    exactly
