HELP!!!! this one is interesting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Aug 10, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    all of a sudden my blazer started running poorly. at idle it feels like it is running on about 7 cylinders(shaky really rough idle). When I stomp the gas, though, all power is there. While cruising though, the truck will sort of sputter as if it were getting no fuel for a quick second. it will do this sputter two or three times and then is fine. If i use very little gas i dont have this problem. What could this be. my wild guess might be fuel pump or fuel filter but this just began half way on my way to work today.
  2. xswede
    xswede Registered Member
    Aug 10, 2003
    22
    SWEDEN
    You might want to check your vacuum hoses. Make sure you don't have any leaks.
    Good luck,
    Dan
  3. zach78k5
    May 14, 2000
    406
  4. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is this for the 85 in profile? Sounds like the same problem I chased for YEARS. It turned out to mainly be the EGR. Not sure how to check it, but the EGR solenoid went bad and was not letting the valve operate correctly. Idled crappy, had somewhat ok takeoff, but had poor cruise characteristics. Check that solenoid! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Have you checked your fuel filter? Maybe its partly clogged and only allowing gas to get through at higher RPM's.
    Kris
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    EGR valve stuck open. The '78 may not have a solenoid, it might just be operated off a ported vacuum port on the carb. The EGR valve itself might just be carboned up. The EGR valve should always be closed at idle.
  7. zach78k5
    May 14, 2000
    406
    I will try that as well as the fuel filter. Where is the EGR solenoid located?
