HELP...time sensitive...need D60 brake brackets, or CUCV brake calipers
Discussion in 'The Garage' started by Highjaxx, Jul 22, 2005.
  1. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Turns out i have a military D60 front, the brackets are fine, but domestic D60 calipers dont seem to fit, so i need calipers to match the Bendix brackets, or i need to get some standard Dana brackets.
    If these can be acquired from somewhere new, or remanufactured, that would be prefered as they are brake parts.
    Thx for everyones help.
  2. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    Brackets are brackets, the fact that it's military doesn't matter. I suggest that your brackets (or possibly the reman calipers) are worn causing the (I assume) excessive slack. Several aftermarket manufacturers make the slides in varying thicknesses to help with this problem.
  3. dyeager535
    26,980
    If it helps any the CUCV manual I've got shows
    2238739 and 2238740 as being "all but M1009 brake components". The description is "caliper assembly left" and "caliper assembly right" respectively.
    Those should be the GM part numbers, hope that helps in some way.
  4. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    thxs...ill try those part #'s
    actually the tolerances are too tight?
    cant get all the shims in place to hold calipers on, had to hammer the original brackets in,(split one doing it)<---not correct :P
    so any way, if there are any more ideas im open, thx again
  5. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    So you split/broke the actual caliper bracket while hammering in the wedge under the caliper? :eek1:
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you are talking about those brackets that the calipers mount to, I've got a pair of used ones in good condition in the shop you can buy for $50 a pair plus shipping. :deal: :waytogo:
  7. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    i split the small mounting hardware shim brackets that the retaining bolt goes thru.
    Ill talk to you about those brackets shortly. :D
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Post pics of the brackets, shim, etc. so we can get a visual on this. :waytogo:
  9. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I think he means he broke the retainer that i'm driving out with a screwdriver in the Pic below.
    Is the caliper seated all the way at the top??? I've never had much trouble with mine. Is the spring portion of the retainer in the correct place?? On top of the retainer??
  10. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    that is the piece that i split, it wouldn't fit alone, there is no way the thin piece of metal would go on the other side
    the shop trying to fix what i did has spoken with dana, and they said all GM trucks came with all dana parts, (bendix is military?, i have bendix :( ), or this is what we have come to believe, the calipers are close to fitting
    im trying to get ahold of some original dana brackets, since we've gone thru about every D60 brake caliper to try and match
    maybe im overlooking something easy, but i think the military used different calipers, and im trying to make this easy to get parts for
    lol, the saga continues
  11. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    As far as I know the brackets on all GM version D60's are all the same.
    Fwiw, I have mixed & matched caliper brackets on civilian and CUCV axles with no problems, In fact, the the front axle in my crew cab is a CUCV axle and while it was a USAF truck it appears to be civilian spec. The crew cab calipers fit the CUCV axle just fine.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nope. There is no difference in brackets or calipers. All the same thing. Bendix is a very common name associated with brakes. Its like Dana is associated with axles and parts, Bendix is where the brake parts come from.
    Don't try to confuse yourself or others for that matter. Nothing is different between the brackets and calipers from a military and civilian version D60 front. Nothing. Absolutely nothing. You may as well save yourself the time, hassle and headache and forget the "quest for the correct part number." You won't find it. There is none.
    I'm gonna bet you didn't have the caliper seated squarely or correctly on the bracket in order to get the shim-thingie back in. Hence the reason it messed up. If you are still interested in my brackets, I quoted $14 shipping for the pair to your door.
    If you want, go to your favorite parts store and cross reference their books what you said. I'm gonna say 100% will say they all share the same part number.
  13. dyeager535
    26,980
    Just to back that statement up (that they are the same) just pulled the '85-89 parts manual, and the part numbers are the same as the one in the CUCV part manual.
    Those numbers I posted before are wrong, no idea what they are, (lists calipers under 4 different part numbers) GM parts manual uses 14002543 for LH, and 14002544 for RH. CUCV manual shows the '43 number as well. Apparently the military only had brakes on the LH side. :wink1:
  14. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    I had similar problems installing new calipers on my M1008. After all it was so tight I screwed the new caliper off and laid it next to the old one for comparison.
    I found out that the new one had some kind of a small nose on it about 3/8" longer than on the old one. This nose interfered with the knuckle IIRC (could be another axle part though).
    Some work with a cutting disk on the caliper and I was done!
  15. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    i cant get the shop to stop trying to find an off the shelf answer and just take 5 mins to look at the darn thing, i know i should just do it myself, but ive been neck deep into this truck so long im just flat tired
    why cant a mechanic just repair something!
    ok rant over
    does anyone have DANA caliper brackets on their truck?, does anyone have Bendix calipers to match their Bendsix brackets, this is getting to be out of control, and the best part is its costing me money :P
    im glad i have you guys for help, and to listen to me complain
  16. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    going to take my truck to 4wdfactory in a couple days since i live so close, thx again for all the advise fellas
    atleast greg wont get confused because its a 4x4 :D
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    Again.......there is no "DANA caliper bracket." Its all Bendix cast on the brackets.
