help! took off body lift and steereing is tight.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Apr 9, 2002.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    is there an adjustment to be made on the steering shaft itself?
    thre looks to be a couple ofholes in the shaft. is there a pin on he bottom that will allow me to shorten the shaft? i didn't put the lift on so this is new ground to me.
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I would assume that it would have to be loosened up and shortenend just the oposite of when it was installed .....
  3. CAROLINAK5
    Aug 2, 2001
    242
    yea...but how???????????????????
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    If they have not modified the shaft at all the best thing to try would be to loosen the 2 bolts that clamp around the column at the firewall (15mm) and the two bolts under the dash vertically (15mm) and the four bolts under the column (1/2 usually gold) then pull the entire column towards the cab. Pushing the entire column forward is how most body lift kits suggest to do it; so I would suggest the opposite. If that doesn't get it let me know and I will go into more detail on a pin fix. Also don't quote me on bolt size but that is close for off the top of my head.
  5. CAROLINAK5
    Aug 2, 2001
    242
    bolt/nut sizes were correct. i had to grind/drill out the fasteners that were installed in the steereing shaft when the lift was first installed. who ever put it on lengthened te shaft, so wit a little penetrating oil and a lot of persuasive hammering, all is well.
    thanks for the help.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    No problem glad you got it all done ;-)
