HELP! Tranny bellhousing bolts.
Discussion in 'The Garage' started by Jonny-K5, Jul 10, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    im swapping trannies today and im stuck on the top bellhousing bolts. how are you supposed to get to them? i cant even see em. my truck is an 89' so it has a bunch of crap on it. tranny is a 700r4
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    LOWER THE BACK OF THE TRANS down about 2 inches you should be able to see them then. from underneath I'm assuming /forums/images/graemlins/waytogo.gif
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    With everything in place i have gotten it using a 9/16" box end, and stuffing your hand down past the distribuitor....
    You know how the box ends are slightly angled.. use the angle so the wrench points towards the front of the engine.
    (The other way around than i would usually use a box end.)
    Otherwise, ya lower the tranny as far as you can, and some long extensions and a swivel socket might do it.
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ok thanks, i'll give it a try
  5. dyeager535
    26,980
    I've also RAISED the tranny to tilt the engine forward for better hand clearance for those bolts.
    I'd probably put the bottom two back in though, so that the tranny/engine don't bind up when the bolts are undone up top.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I used several long extensions with the right sized socket on the end, lay down under it, reach up towards the top of the trans where the bolts are and get'em out. /forums/images/graemlins/dunno.gif
    You CAN get every bolt out from under the truck.
  7. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I lay a 2x4 across the fenders and lay over the engine with my chest on the 2x4 and legs on the core support. Then it's easier to get the bolts out with a box end wrench.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a snapon impact swivel socket and 4 feet of extensions
  9. oilburner
    oilburner Registered Member
    Jun 23, 2004
    14
    Montgomery, NY
    The best way I have to get those bolts is by lowering the tranny&tcase combo until the Dist. is about to hit the firewall, then use every 3/8 extension you have to reach up and get them from underneath. My trucks are tall enough that you can sit on the ground behind the Tcase and look forward and up, and see the bolts. If you can see 'em, you can get several feet of extension on 'em.
    G /forums/images/graemlins/crewcab.gif /forums/images/graemlins/k5.gif
  10. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    this is what i did to get those bolts out, now im putting the new tranny in today, whats the best way to get those back in? . any tricks for doing this? should i try to get them in with the extension or wiggle my hands up in there.
  11. oilburner
    Jun 23, 2004
    14
    Montgomery, NY
    If you have a stiff 3/8 drive universal joint or universal socket (esp one with the spring around it), use it on the end of the long extensions. Start the bolts WITHOUT using the ratchet (so as not to cross threads), then put the ratchet on and torque to spec. Of course, if you can get an arm in there, that may prove easier - I never could fit my arms up there /forums/images/graemlins/wink.gif
    G /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I have no carpet in my '78 so pulled the access cover off that sits over the trans when I changed it and those top bolts are right there in front of you...piece of cake! /forums/images/graemlins/thumb.gif
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I was reading down through this thread wondering when someone was gonna mention that. I just installed my motor last night and used that method. No tranny tunnel cover makes it waay easy. You can reach in there and start the bolts with your hand. Then use two 6" extensions and a universal to tighten them up. /forums/images/graemlins/peace.gif
  14. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I'll take this /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  15. dyeager535
    26,980
    Because the later tunnels are welded in place.
  16. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thats what i thought, i didnt see any bolt holes from underneith.
    well its all back together now, thanks for the help everyone~ /forums/images/graemlins/thumb.gif
  17. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    DOH!!!!!!
    Haven't had the carpet up on my '91. /forums/images/graemlins/blush.gif /forums/images/graemlins/thumb.gif
