HELP TRANS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jul 28, 2002.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    So i had to go to Fedexs main warehouse to get my trans(700r4}. i installed it and got everything back up with Tcase and all
    but when i ran it it will not engage reverse. this is a newly rebuilt trans i bought so if anyone knows what i can do let me know
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Check fluid, when you fill it should take 10 to 11 quarts!!!! You filled it while it sat, then ran it, then it filled the torque converter........ You need mmore fluid! Reverse is the most sucking gear for fluid!
    Check fluid, run engine in Nuetral, Check Fluid, Switch gears(Don't Move though), Run through them up and down, Check Fluid, Up and Down, Then test drive, Check Fluid, Check Fluid, Check Fluid, and so on till all levels out! /forums/images/icons/cool.gif
