Help!!! Transmission won't shift out of 2nd... 700r4
Discussion in 'The Garage' started by mr.smartass, Sep 4, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    89 k5 350/700r4 10 bolts, did a little mud riding last night and when i was done my buddy unlocked the passenger side hub and i relocked not knowing he had unlocked it... put it back in 2h and started down the road and it was acting a little funny and wouldn't shift out of 2nd into 3rd when it comes time to shift it just hits high rpms. i stopped at a gas station and checked the fluid, it wasn't touching the stick so i added a few quarts and discovered the hub was still locked, but it's still doing it, this is probably caused by the low fluid and has nothing to do with the hub, am i just screwed or what? any input is appreciated.
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    sounds like time for a rebuild.... :(
  3. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    have you taken the pan off of the tranny yet ? how many miles on it?
  4. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    added a few quarts????:shocked: :eek1:
  5. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    :eek1: yep thats why TONEYD19 does not have k5 to drive right now. he blew a tranny line and drove home dry but added a few on the way...... it lasted about 2 weeks after that. :doah:
  6. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    about 160,000 on it, but i can't figure out where my fluid went... rear seal leaks a little but not that much... and no leaks i can tell and i checked it not to long ago... haven't pulled the pan yet... haven't had time i've just been driving it in "2"... should i just park it for now until i have time to pull it?? and what am i looking for?
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    your looking for Chunks, glitter, clutch material, and burnt fluid
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    A 700 that wont shift out of 2nd is a tell-tale sign that its gone. Time for a rebuild or new tranny
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Not to hijack the post, but I have one I just got in a K5 that goes into gear... forward and reverse, but won't shift out of 1st gear. Is that pretty much the same indication of a bad 700R4 as not shifting out of 2nd gear?
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    yes
    No shifting = No good
  11. mountainexplorer
    Nov 14, 2001
    4,903
    I know on other tranny's, like TH350's a small problem like the vacuum modulator not being hooked up can make it not want to shift... wasn't sure if there was anything on a 700R4 that was electronic or whatever that could be disconnected or bad to make it not want to shift.
  12. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    Actually, You are right to a point, but i dont agree with the trans being bad just yet, theres several things that can cause a no shift situation on a 700R4. a rebuild isnt needed if the thing air checks good and just has a sticky governor or 1-2 shift valve... Nate
  13. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    x2 !
    Yeah,check the nylon govenor drive gear--I nearly put a tranny in my 81 G10 van for nothing--all it had was first and reverse!--my friend said to make sure that gear was good before condemming the tranny--sure enough,it was all stripped!--looked like an apple after you ate it!..put in another govenor from a boneyard tranny,and I've driven it 45,000 miles since with no problems!..:crazy:
  14. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    interesting... i've never really done much tranny work though it's all kinda greek to me... i got a buddy who might look at it for me, but if he does say it's fried... i was just wondering what it would take to bolt a TH400 into my '89 k5... it's all stock... 350 and i suppose a np241 i think... just wondering if i need to change transfer cases or whatever...
  15. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    that's exactly what mine did when it died, second only, and slipped pretty good going into THAT one.
    160k??? you got some ok mileage out of it, mine lasted until 215k,,now runnin right close to 250k:crazy:
