Help trouble shooting hydroboost problems.
Discussion in '1982-Present GM Diesel' started by Shannon, Jun 17, 2002.
  1. Shannon
    Shannon Registered Member
    Mar 6, 2002
    6
    Kansas
    Have an 86' Sub with a 6.2 diesel. The brake fluid from the rear reservoir on the master cylinder has been dissapearing. There is a small hole inbetween the master cyl and hydroboost unit on the bottom and is leaking out of there. Would it be a correct in thinking the rear seal of the master cyl is out or could it be a seal problem with the hydroboost? Little scary when you try to stop and the pedal goes to the floor.
    Shannon
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Hey your master cylinder is leaking . If the hydoboost was leaking you would see a drop in power steering fluid
