HELP!!! TRUCK DIED!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Dec 15, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    Hey, I was on the trail last night. and just after I locked my hubs I got in and my truck died, (ran smooth, then nothing)
    Got out and many of my mechanically inclined friends determined that the ignition coil on top of the distributor failed.
    After replacing this And putting it back together we didn't get it to start but we took off the coil cover and the electrical current was arching all around the wires within the housing ( when trying to start it) and I went back and got another One and still had the same effects?
    Please help my friend and Ihave no Idea right now what it could be.......Any Ideas would be greatly appreciated.
    1979 Jimmy 4" skyjacker, add-a-leaf, 35" M/T's, Body Lift purchased.
    2001 Pathfinder LE Mile Marker Winch
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    replace the cap and wires... give the inside of the cap a light spray of WD40 to get rid of any moisture...
    did you drench the engine?
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. madups311
    Nov 14, 2001
    72
    VA
    The engine is dry and I allready did the cap and wires..????
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Did you ground the coil?
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  5. madups311
    Nov 14, 2001
    72
    VA
    YEAH, by screwing the black wire down to one of the (4) screw holes that holds down the coil??? This I did do
    Please keep the suggestions coming!
  6. Grim-Reaper
    7,385
    Atlanta
    There is supose to be a metal peice that also gets screwed down with one of the screws that holds down the coil and it goes up to where the wires connect. It's the ground strap....is that in there? Did you put the rubber pad and Dielectric grease down where the contact spring goes?
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  7. madups311
    Nov 14, 2001
    72
    VA
    Please, I have done all this Unless I should dieclectric grease everything under the ig. cap then please offer other solutions ...I relly tried all these options before postingthis message...this seams to be a one in a kind experience...I appear to need those that are particularly inventive????
    Still all help is greatfully appreciated...I'm dead in the water here!
  8. 88k5donger
    88k5donger Registered Member
    Dec 14, 2001
    5
    Hey if you anyone that ha a VAT 45 battery tester or you could just go to a shop, but it could be that your battery is overpowering the coil. Too much energy from alternator, check your battery voltage, making sure it is no higher than 13.1 or so.
    Just my 2 cents.
    Dave
  9. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Do you have spark at the plugs?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  10. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Sounds like typical HEI ignition module gone bad. Check for spark and if you still do not have it you have a bad module or
    pick-up in the dist. Let us know what you find.
    T.J.
  11. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    It definately sounds llike somethings loading up BIG TIME. Kind of all dressed up with nowhere to go. Other than tearing apart the distributor and replacing the module and pick up it sounds like another distributor is in order. I picked one up at Autozone a few years ago and it's been returned twice with no q's or hassles. Good luck, let us know what it is/was!
    Jim
  12. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Just a thought check the insulation on the wires going into the cap. My last dist. had no insulation what so ever.
    Jim
  13. dyeager535
    26,977
    Are you getting spark at the plugs? Maybe I'm not understanding this correctly, but put the cap back on and see if it is.
    Maybe you have already? If you are getting spark, I'd be thinking fuel pump for an "all of a sudden" no start condition.
    just some more ideas.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  14. madups311
    Nov 14, 2001
    72
    VA
    I'm not sure what kind of insulation that I would need to do to the distributor...and to others it seems that the power is coming in the red wire and just arching over towards the back
    part of the housing
  15. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    You don't need to insulate the distributor, just check to see that the 3 or 5 wires on your distributor are still insulated. Maybe one of them is grounding out on the case?
    Jim
  16. madups311
    Nov 14, 2001
    72
    VA
    ???Where does current go to that is looking for ground, it appears to me that if you screw down the coils black ground wire that current still stays in the top part of the cap, unless there is a wiring within the cap that goes to ground, I'm just not seeing it???
    And JJ there is about 1/4 inch of wiring exposed on both the red and yellow coil wire
  17. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I'm not sure but I think that black ground wire is more of a bleed wire. Theres alot of voltage going thru that coil, up to 25,000 volts. The other aluminum strap is more of a ground/neutral.
    I was telling a buddy about this he was thinking maybe a broken shaft in the distributor. All that juice is being loaded up and it's not moving whjere it needs to go?
    Jim
  18. madups311
    Nov 14, 2001
    72
    VA
    It's definately not going where it needs to, but what do you mean BROKEN SHAFT???
  19. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    A broken distributor shaft or maybe the camgear fell off. In other words the rotor isn't spinning and distributing the charge to each plug wire. Remove the cap and see if the rotor is spinning when you crank the motor.
    Jim
  20. madups311
    Nov 14, 2001
    72
    VA
    I'll give it a try, thanks
