Help - truck dies at lights as well as on the freeway!
Discussion in 'The Garage' started by Topdown, May 19, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Hey all,
    well, I got the new engine in and well... its got a few problems. I am running a holley street avenger 670 cfm carb and I cant get the darn truck to hold an idle at lights or for that matter when I am in traffic on the freeway!
    Right now it wont even hold an idle sitting in park in the parking lot here at work.
    Help
    -Ryan
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    check the butterflys to make sure that they are closed when your at idle...
  3. Grim-Reaper
    7,385
    Atlanta
    Holly <------Your problem.
    Sounds like the choke is stuck on or you have a vacuum leak.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    [/ QUOTE ] id agree with that /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif also look for a vacume leak
  5. Topdown
    Nov 26, 2002
    2,598
    Ok... I will search for a Vac. Leak.
    There are only 3 vac lines that I am aware of in the truck, so it shouldnt be terribly difficult.
    Brake, Tranny & Dist. - unless you count the PCV.
    -Ryan
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it could also be the intake is not sealed and is leaking so spray starter fluid around the intake and see if the rpms go up
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    turn your idle up
    lol
  8. Topdown
    Nov 26, 2002
    2,598
    /forums/images/graemlins/crazy.gif
