help!!!!Truck is running bad
Discussion in 'The Garage' started by the fall guy, Dec 20, 2004.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    My 85 Blazer is running horrible. especially when cold. It is all stock [305] but has a holley street avenger carb on it. When it is warm and i hammer it....then let off....a puff of black smoke comes out the tailpipe [is this normal???]. When i take off when cold it stalls and sometimes it burps through the carb. Any help would be greatly aprreciated.
  2. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Black smoke can be caused by one of two things, 1. Too much fuel (ie. running rich) or 2. Blowby (valve seals or piston rings are gone).
    Personally what I would bo would be a complete tune up on the thing (ie. new spark plugs, wires, cap, rotor, 02 sensor if so equipped, pcv valve, air cleaner, crankcase filter, check the timing, etc, etc...) and then I would look at the carb and see if it's jetted properly, an egt guage or pyrometer will help you in this department.
