Help! truck won't start
Discussion in 'The Garage' started by 84k5, Nov 1, 2003.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Help! truck won\'t start
    84 305. all stock.
    It rolls over, starts, then immediatly dies. I was able to get it started by holding the pedal maybe 3/4s down and not letting up for a minute. It was puking smoke and ran rough, then recovered and idled fine after another minute.
    I searched a bit and I'm thinking fuel filter or pump from the stuff I was seeing. My question is...is there a way to check these short of just replacing them? It's kinda lame but I pretty strapped right now and I really don't have any money to throw at it. Also, any other ideas welcome...would like to get it to run today...there's actually gas in it so I could go somewhere. Thanks a ton. You guys rule.--Brian
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Help! truck won\'t start
    what color was the smoke? hows the coolant and oil look??
    fuel filters are cheap and easy to change, and pumps arent TOO bad either..but i dont think its either of those, yet..
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    ok..that was last night so I went out and started it up again just now.
    Started easier, ran a little rough. Decent amount of black smoke for maybe 10 seconds. Oil and coolent look ok. It is making noise from passenger side valves (I think). Only on that side. Also, it started making a sort of 'click' every few seconds. Ideas?
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Does the truck have a carb or tbi....
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    carb. Seems to be on and off. Fires right up sometimes, other times I have to fight it. And then it smokes and runs rough for a minute before calming down. I'm goin change the fuel filters and see where that gets me.
  6. 99firehawk
    Dec 15, 2002
    491
    IS your choke working? I would be checking for a big vacum leak
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    if it was that bad of a vacume leak you would think you could hear it..id pop the hood and listen for onee..
  8. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I could not hear anything that sounded like a huge leak. What's a good way to check for a small one? Just a real good visual inspection? How would I check the choke? Thanks for the help guys.
  9. 99firehawk
    Dec 15, 2002
    491
    electric or manual choke?
  10. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Check your float level yet?
    You could check for a vacuum leak by spraying some WD-40
    around the intake and listen for a rpm increase /forums/images/graemlins/grin.gif
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with firehawk's line of thinking. It sounds like your choke is sticking shut.
    Since your 84 comes factory with an elctric choke setup I'm gonna assume you're still equipped with one. Have you taken a look and made sure that your choke is pulling off properly? Pop off the aircleaner lid. Get into the truck and set your choke and high idle by putting the pedal to the floor(make sure your engine is cold or it won't work properly). Now get back out of the truck and check that the choke butterfly is closed. Get back in the truck and fire it up. If it stalls out, get out and look closely at your choke butterly again- it should have opened up about 1/4 of an inch. If it didn't it means you're gonna have to make an adjustment on the pull-off linkage.
    BTW, black smoke means too much fuel and if your choke is on when it shouldn't be it will lead to a rich-running condition.
