Help tryin' to wire tach!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Mar 20, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Help tryin\' to wire tach!
    Ive got the power, ground, and the lights hooked up but I cant figure out where to hook up the ignition wire on a 84' 350 with a HEI dist. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Re: Help tryin\' to wire tach!
    Look on your dist cap,should have batt wire and 1 male terminal next to it.Stick a female terminal on your wire and stand on your head to get it in good and tight lol. /forums/images/graemlins/grin.gif
  3. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    No luck, cant see wire, where is it at, I see 3 coming out from front and going back in on the driver side of dist. and 2 coming from driver side but no wire with male plug on it.
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    does your coil sit on top of your dist. cap or next to it on the manifold?
  5. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    On top of dist. cap.
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the dist. cap on my '85 had a spot next to the battery hookup that had tach written on it. I know that's where we plugged in the tach on the '78 that my brother used to have.
  7. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,595
    768
    City of Sand, UT
    The distributor cap on my 250 i6 has a spot labeled for the tach right next to the ignition wire. dont know if its the same on a 350, but if its the factory cap, there shouldnt be any reason for there not to be. good luck. electronics are annoying. /forums/images/graemlins/tongue.gif
  8. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Is it a pink wire next to a thicker gauge wire in the driver side of the dist? /forums/images/graemlins/1zhelp.gif
  9. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Got it going, Thanks fellas /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    glad we could help. /forums/images/graemlins/thumb.gif
