help u joint 10 bolt to 12 bolt
Discussion in 'The Garage' started by the excuse, Jan 12, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    any one know the u joint needed to connect the drive shaft to the axle it is a driveshaft from a 10 bolt going into a 12 bolt axle. a napa part number would be very helpfull. thanks.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    depends on your transmission..
    my sm465 10 bolt (1350) to 12 bolt was a precision/napa 348..
  3. the excuse
    Dec 9, 2003
    209
    san diego
    its an auto 350 engine and 350 trans. im also having serious trouble bleeding the brakes. i cant get the pedal to firm.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3-3130 gets you a 1310 to a Saginaw S44 in a Neapco, which most parts stores carry.
  5. Confedneck
    Nov 1, 2002
    5,236
    bleeding the brakes can be tricky.. bleed the master first.. then crack the line on top of the prop valve on the frame and tap the valve a couple times and close the line up.. then bleed the RR, LR, RF, then LF.. all until there is no more air coming out, fluid only..
    for the ujoint, someone may have the part number handy.. but.. if you go to napa, and tell them what you have---
    year of truck, 4x4, transmission, and that you're putting in a 12 bolt, they can cross reference and bring up the right joint.. for some reason.. im thinking its 331..
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    See my post for part number. /forums/images/graemlins/thumb.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    3-3130=331 precision?? just wondering for my own knowledge /forums/images/graemlins/ears.gif /forums/images/graemlins/thinking.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    331 in precision is the same as a 1350 joint, which would be part number 2-0053
    Precision's part number for a 3-3130 is 350.
  9. Confedneck
    Nov 1, 2002
    5,236
    damn you're good.. /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm not that good, I have the catalog no further than arm's reach from me when I'm posting for this very reason.
  11. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    here is a thread that I started to get these numbers a while back. It has most of the conversion ujoint part #'s. here
    Rick
  12. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Agreed! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif And if you hadn't I would have /forums/images/graemlins/grin.gif
    John
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    So you got a driveshaft out of a truck/blazer that had a 10 bolt in it and you are going to use it in your 12 bolt equipped truck? Is the u-joint on the 10 bolt bigger? If so, get the yoke off the 10 bolt and put it on the 12 bolt! You just need a special seal. I dotn know the part number for the seal off hand but any rearend place will know.
  14. the excuse
    Dec 9, 2003
    209
    san diego
    im putting the 12 bolt into my blazer. i have no way of getting the yokes off the 12 bolt and the 10 bolt because the 12bolt is installed and the 10 bolt is on the ground. i dont have an impact wrench to remove the nut. i called napa and they cant bring up precision u-joint 350 they say it isnt in the computer. my truck is on jacks in the garage so any help is good.
