Help! Under Dash wiring
Discussion in 'Southeast Region' started by grimjaw, Jul 10, 2006.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Well, this is another fine mess I have gotten myself into....
    There was once a Viper Alarm in this truck when I got it. It sucked. I was cause choas in the truck, So I removed it. This was two years ago.
    Fast forward to a few weeks ago. I did to get a bunch of stuff fixed or upgraded in the truck before Tellico. I drove the blazer into the garage and started to work. I wired a 220v outlet in to the shop for my new compressor, swapped out the rear lift blocks for springs, converted the rear to disc brakes, etc. Then I started on the electrical. I have had a problem with the old battery isolator so I bought a Painless Dual Battery controller. It was going smoothly until I needed to find hot wire in Start and Run mode only. I climibed in the truck to find my wire. First thing I saw was the rats nest of wires under the dash. I pulled the old stereo and a bunch of wires from an old two way radio install. Then the part were I went stupid... I decided to remove the left over wire from the alarm. Bad plan.
    I should Have taken a few pics before starting at least or checked a wiring diagram, but no.
    This is what I have now.
    I have bought a copy of the 1991 Chevrolet Factory Wiring Diagram but it will not get here in time to make Tellico. Does anyone have a wiring diagram of that block in the first picture for a 1991 7.4L ????
    Thanks for any help.
    you may now start laughing and pointing fingers at the big dummy.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Sounds like the PO was he dummy....................:mad:
    What is/ain't working? :confused:
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  4. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    The PO (AZblazor) was smart, he just added the stereo and two-way radio. The PO before the PO installed the Viper (piece of crap alarm). If I did not get carried away and just removed one wire at a time I would be ok.
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
  6. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  7. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
