Help Upper Shock Mount/Bracket!!!!!
Discussion in 'The Garage' started by coptezr, Feb 18, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    How do you take the upper stock shock bracket off? its not on there with nuts its has round cap things?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    They are rivets use a torch, BFH, chisel, grinder, what ever you have. It ain't gonna be fun.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    helps to drop gas tank,grinder and air hammer work the best
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    Well, if he is trying to remove the "front" upper shock mounts dropping the gas tank might be a little extra work. :crazy:
    You can drill them out also, but they do suck.
  5. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Yeah it wont fun and make sure you hold on that grinder good...I nearly got a free visit to the E.R when i was cleaning my gas tank and the wire brush caught in my shirt, but my father got it good in the leg when he was cuttin on a bumper, the grinder jumped then caught in his pants and made a nice gash in the leg.
    Just sayin that cause i forgot myself how dangereous are those grinders;)
  6. coptezr
    Jan 13, 2005
    342
    thanks for the help guys i just got it done.:mad:
  7. beaterchevy
    beaterchevy Newbie
    Apr 17, 2001
    British Columbia
    I've done alot of rivets and the easiest way to cleanly remove a GM rivet is with a torch and an impact chisle. heat the head till is bright red and impact it off. You can strip a frame apart this way pretty quick without screwing anything up.
    Without a torch or air -center punch then drill 3/8" just deep enough to get the point of the drill bit past the head of the rivet and cold chisle the head off. never takes much of a hammer to get em off this way.
    Grinding them off is a pain in the ass. way more effort.
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    One word!
    Eye protection!
    My friend lost an eye in 1977. They don't grow back!
