Help! Vacuum Diagram Needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tlsmikey, Apr 8, 2006.
  1. tlsmikey
    tlsmikey Newbie
    Feb 27, 2005
    4
    san jose, ca
    I need some help guys. I have a 1977 GMC K10, 350V-8, Quadrajet.
    The truck has had a new painless wiring kit installed, new motor ..etc. The bad news is that I never took pics of the vacuum lines and threw away all of the old crusty ones. I can't figure out where the lines are supposed to go. I've looked at Haynes and Chelton. Both have horrible diagrams.:mad:
    Does anyone have access to the factory manuals? Anyone have a vacuum diagram for this type of truck?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  3. dlferry
    dlferry Registered Member
    May 8, 2004
    6
    Send me your email and I will forward you what I have found for a 78
  4. tlsmikey
    tlsmikey Newbie
    Feb 27, 2005
    4
    san jose, ca
    Vacuum Diagram
    Those vacuum diagrams look like the same ones from the Chelton manual. They're a good start but if you look at the one for the 350 V-8, heavy duty, california model (what I have)....you'll notice that there are several connections open. I'm trying to figure out where those connections go. I also have what looks like a small round vacuum reservoir with two fittings. I'm assuming one goes to the carb (ported line), but I have no idea where the other one goes.
    You can email any diagrams at tlsmikey@sbcglobal.net.
    thanks for all the help so far and keep it coming.
  5. TEXICAN
    TEXICAN Registered Member
    May 27, 2005
    30
    TX
    313 Hp and 387 ilbs. The transmission leaks so i was gonna replace the seals i wasnt sure if need a upgrade any thing.
