Help w/ Dad's 69 Bonneville 428
Discussion in 'The Lounge' started by Ressurection, Sep 6, 2005.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Does anyone have a manual for this engine? I'm specifically looking for the vacuum routing. Where does the line from the spark advance (on the distributor) terminate?
    Thanks!
    Pete.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Should go to one of the ports on the carb. if memory is correct.
  3. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    hmmmm...
    If its like the 400 my 69 GTO had,the vacuum advance hose went to a thermal vacuum switch on the thermostat housing,which had 2 other hoses--one went to ported vacuum,the other to manifold vacuum--so it could advance the timing at idle to lower the operating temparature,when it got close to 220 degrees in hot weather--otherwise it ran on ported vacuum like most other GM's did..you could probably just hook it up to the ported vacuum port on the carb directly--doubt if it would know the difference!.. :crazy:
