Help w/ setting new seals in T-case adapter
Discussion in 'The Garage' started by ironnut, Mar 12, 2005.
  1. ironnut
    ironnut Registered Member
    Jul 14, 2004
    77
    Missoula, MT/Redmond, WA
    My tranny has been pushing tranny fluid into my t-case(th350-np205) so I pulled the t-case to replace the seals, on both sides of the adapter. One seal was busted so I think i found my problem, but my real problem is getting the new seals into the adapter w/out ruining them. Anyone who has replaced these seals got a good trick? I replaced my seals before but not the way these are seated. The thin lip of the seal is all I have to drive the seal down. So far ive tried using a block of wood, didn't work, the old seal on top to drive it down, didn't work, and ive used a metal punch lightly to tap it down but it is bending the lip. It's at a point now where there is no part of the seal i can hit to drive it down without ruining it. PLEASE if you have done this let me know what you did. Thanks
  2. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    realy big socket set and match up the seal to a socket and dont make the mistaake i did one time when i was new to this. the spring side of seal to the oil side of object. and did any tcase fluid get in your tranny? if so flush the tranny thay dont like gear oil at all.
  3. ironnut
    Jul 14, 2004
    77
    Thanks sweetk30, i forgot about trying that, luckily I have a set of sockets for my tractors, took a 1 7/8 socket. Thanks again, you wanna come over and help me stick the t-case back in? just kidding. :D
