help want to drive my k5
Discussion in 'The Garage' started by gunner2000, Apr 9, 2006.
  1. gunner2000
    gunner2000 Registered Member
    Mar 25, 2006
    30
    bentonville ar
    need a littlie help on a timing problem:mad:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    might get better help if you were to post this in the Garage :thumb:
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Can you be a little more specific?
  4. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    87 tbi, went from a 305 to a 350, now i can not get the timing to set, went by the specs the cam came with, 5 btdc
  5. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    87 tbi went from a 305 to a 350
  6. dyeager535
    26,980
    You disconnected the bypass wire (lots of posts describing the wire on this board) before trying to set base timing, then set base timing at 0*?
    5* is a lot of additional timing, most that have tried timing that far advanced on TBI haven't had good luck.
