HELP....went from runs great to no start any ideas??? *DELETED*
Discussion in 'The Garage' started by gtkustoms, Oct 6, 2002.
  1. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    Post deleted by gtkustoms
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: HELP....went from runs great to no start any ideas???
    It sounds like you're getting either too much or not enough gas. What happens if you hold the pedal all the way down when you crank the engine?
    Have you checked to see if your choke is stuck closed?
  3. Can Can
    15,552
    136
    Sorry, I missed the part about trying the new carb......
    I guess I'm stumped!!! /forums/images/graemlins/rolleyes.gif
    EDIT:
    Is your engine equipped with a oil pressure switch that powers your choke? Maybe it's gone bad......
    And I hate to bring this up, but are you sure you're not out of gas? I know similar problems have ocuured for other guys and it ended up being an empty gas tank /forums/images/graemlins/blush.gif.
  4. gtkustoms
    Oct 6, 2001
    281
    nm
    choke is electric
    it is not run by the oil pressure switch(mechanical gauge)
    and it has plenty of gas.
    it acks like it wants to start when you have WOT, but i think that is from the gas you just dumped into the engine.
  5. blwnbwtie
    blwnbwtie Registered Member
    Jun 4, 2002
    72
    LA California
    just a guess but clogged filter reducing fuel pressure or bad fuel pump maybe? getting spark too all 8 cylinders?
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Fuceable link ?????
  7. gtkustoms
    Oct 6, 2001
    281
    nm
    brand new electric fuel pump, brand new filter
    disconnected it at the carb shoots out like a mother fooker
    z3pr there are no fusable links on the truck brand new painless wiring harness
    /forums/images/graemlins/confused.gif
    thanks
    for the ideas
    travis
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well this is what i would do, i would either dump gas directly into the carb, or spray it with carb cleaner and turn the motor over see if it catches, that is what we have to do with my friends dads ol gto, check it out some more, im sure you will feel very stupid\happy when you find the problem and fix it /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    just a possibility , you might have flooded it from the
    beginning and fouled out some plugs. check your plugs.
    also, how bout the timing? could it have moved or jumped ?
    good luck
