HELP! WHAT IS THIS?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 21, 2002.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I will try to explain. i just got my head back from my 350. i see the push rods, the rockers, the studs and bolts and these little things that i cant figure out. they are about 1-1/2 inches tall cylinders. one end is totally sealed and covered but the other end appears to have some bearing held in by a clip. i assume it it part of the head or rocker assembly. if you have a clue what it is or where it goes please let me know. the head is not new it was pulled off my old engine by my brother. long story. where do the lifters go?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Lifters
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    It sounds like a lifter, which goes in the block not the head. With it being part of the head it would be the springs but you can tell a spring by looking at.
  4. radar
    radar Registered Member
    Oct 28, 2001
    26
    a GOOD mechanic always has parts left over!
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    that's right makes it lighter and therefore, faster.
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Sounds like a lifter.
  7. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    The lifters go in the block. There are little cylinders that these fit into in the center of the engine right above the camshaft. The flat end goes down and rides on the camshaft, and the cupped end is what holds the push rod and lifts it up.
