help...What would you do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Dec 28, 2001.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    43
    Wichita, Kansas
    ok...I'm driving and I hear a crunch, look out on the street, theres my driveshaft...damn. So I put new joints in and start it up...When I put it in drive, step on it ...Nothing. So I look underneath.....That rear shft is just spinning away. So...I havent looked yet but ....either the gears or an axle, right. I am a poor college boy, So would you either put gears in (new), or get an entire rear end from a salvage yard. Mind you I have never done this ever, but I am inclined. I can get all the tools... Is putting a new set or gears in that hard? What does it entail. 83' Full 3:08's (stock) Thanks WSUDU
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    All ready done that once and put the spare rear end in. Junk yard SHOULD have 10 bolts for like $35 and a couple hours to replace
    <font color=red>Let me at it I can break it</font color=red>
  3. Definately get a rearend from a salvage yard. Unless you rebuild rearends professionaly, it is not a job to be taken lightly, and to have someone else do it will cost $$$. Save the broken rearend to rebuild w/ bigger gears or scrap it. Most will tell you to upgrade now, but if money is tight, a 10 bolt shouldn't run more than $100.
    American by birth, Marine by the grace of God
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well if you are running 33's with 3.08's and your 400 is really putting out 425hp as you claim, you better get a 14B. it would be much cheaper to get a 4.10 14B then regear the front/swap front. than to regear a 10b or to keep buying new ones every month or so.
    I had this delima &amp; splurged to get the 1 ton conversion. no more broken parts for me[​IMG]! it just too bad my tranny itself is the new weakest link[​IMG][​IMG]
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
