HELP, Whats the best way to get my stubborn intake off?
Discussion in 'The Garage' started by camokrawler, Apr 11, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    My stock intake doesnt want to come off gently, what the best, least harmful way to remove it (properly) I need an answer asap if u can thanx
    camokrawler
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    hook an engine hoist to it and lift? i'd unbolt mind and try that if i couldnt get it to pry off
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you don't have a engien hoist use a pry bar and get it in the seal at the front of the block, that way if you scrach the surcafe it is not as big of a deal as scraching a intake gasket surface. Also make sure you got all the bolts out, on a dirty engine it is very easy for a bolt to hide under some grease and dirt
  4. camokrawler
    Mar 2, 2006
    47
    yep forgot a bolt covered in dirt, but i got it off now. felt like a dumba$$ there is alot of what i think is carbon on the sides of the valley. is this normal? i am clean out the valley really good be4 i pull the pushrods and lifters
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    carbon is normal, be carful cleaning out the lifter valley though, if a lot of the crud falls into the crank case it can clog up your oil pump, last time i did a intake swap i used a shop vac to suck up the stuff while i was scraping it off, it worked really well
  6. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    C4/detcord.:saweet:
  7. camokrawler
    Mar 2, 2006
    47
    alright guys, i am now down to the lifter valley and was trying to be as careful as possible and pick out as much of the crud as i could so i am not too worried. i will change the oil as soon as i break in my cam. i the the timing marks aligned and started pulling pushrods just b4 dark so i'll pull the rest of them in the morning, double check all the mating surfaces and drop in the cam and slap on the intake and if all goes right, it'll run. get r done.
    camokrawler
